My new Deuce
SrIrie
Oregun
Well here are some pictures of my duce when I got it home and now. I thought I would share with everyone and say a big thanks to the people that have posted info on restoring and modifying. Still have a few things to do but she runs and drives like a champ and I can’t stop grinning :mrgreen: anytime I am working on or driving it.
russ81
cambridge, ohio
RE: My new duce
she looks great !!
Getting my new wheels and tires mounted right now. 16 x 20's I'll post some pic's when I get them on the truck.
54reo
62
Chester IL
RE: My new duce
Very impressive, I like the looks of the three-color cab top. It really stands out.
SrIrie
Oregun
Re: RE: My new duce
jodyp said:
Your truck looks awsome. Are those the wheel and tire combos from odiron??
Thanks
No the wheels and tires are not from Odiron, tires I bought from berg tire and I made the wheels
1,158
RE: Re: RE: My new duce
Looks great! Great looking tires. I see you have the front and rear lockouts-how much difference did they make?
SrIrie
Oregun
Re: RE: Re: RE: My new duce
They made a big deference. I had the lockouts before I did anything else to it. With stock tires and the fuel not turned up and with out lockouts, the truck would only reach just over 55 with the pedal flat on the floor. After I put the lockouts on the truck it would over rev and reach 60 and over with ease. Turning also improved considerably it turns a lot sharper with less scrub on the tires.
biodeucel
Potsdam, NY
RE: Re: RE: Re: RE: My new duce
I've heard of removing the driveshaft between the duallies, but not lockouts. Where did you get them for this truck?
SrIrie
Oregun
The lock outs are from www.ouversonengineering.com
The rims take two bud wheels each to make (12 total) and you need a lathe that has at least a 24” swing and a good welder and someone that is qualified to run both. Not too sound like an ars but you have to remember this is a 13,000LB truck you really don’t want a wheel coming apart.
I cut about 5”s from the out side of one wheel and put a 45 degree angle toward the inside on the lip to be welded then using a whole wheel I put a 45 degree angle toward the outside on the lip to be welded. Not only does the two 45’s make it very easy to get the wheel strait and true but your welds are then a bit offset from each other witch makes them stronger. Then cut the outer center out and walla you then have 6 12x20 bud wheels.
biodeucel
Potsdam, NY
"The lock outs are from www.ouversonengineering.com"
Would they be the "DUECE CASTED LOCKOUT"?
That tire size looks great on your truck.
Streetgliderx
Tuscumbia, AL.
thanks cool part is i weld for a living and my neigbor has his own machine shop with lathes!!! i was wanting to do me up some custom rims when i get mine and i been lookin at other designs thanks for the write up sounds like a cool idea.
SrIrie
Oregun
Yes those are the lockouts you will also need one alloy axle shaft If you have any questions just call Ouverson’s they are very helpful And one of the best companies I have ever dealt with in the 4x4 industry
Jakob
Louisville, KY
What size are those tires?
Can you get more pics of the wheels? I've read the write-up elsewhere on the site about doing that, but those were for 10" wide wheels. I'm just wondering how much different they look w/ 12" of width.
