My New "old" CUCV
10thMtn
West Finley, Pennsylvania
IT came , it all worked out !! What a BLAST from the PAST, being behind the wheel of the CUC - V .
Please see the VIDEO, runs strong !! http://youtu.be/Z18GnnmE3t4
Only problem I have now is shutting the old girl off. I believe the FUEL SOLENOID ? is hanging up ? Anyone have any suggestions here ? I take the key out of the ignition she may shut of in 5 seconds , she may go up to 1 Minute.. ????/
I am also in need of the complete radio rack for behind the passenger seat, I have alot of radios I would like to put in this this. Any one help there ?
It is a big hit in the parking lot at work.... what fun...... good memories of good times in that old truck
Matt65
Alabama
Good looking truck.
I would want to have a back up plan ready until the shutdown issue can be fixed. Maybe it needs work on the injection pump shutoff.
10thMtn
Good looking truck.
Like Pinch off the fuel line where it enters the injection pump ?
Am I correct by saying there is a solenoid inside this injection pump?
Will addative help lubricate this mechinism?
I suspect the coil is getting weak or there is not enough lubrication getting to this piston or ? whatever it is ?
Matt65
Alabama
Yes -
TM 9-2320-289-20
2-47
31. WILL NOT SHUT OFF USING KEY
NOTE
Ground wire for ignition switch goes to top of parking brake bracket. If
ground wire is broke, engine will not shut off if light switch is on.​
Step 1. With engine at idle, pinch flexible part of the fuel return line at fuel injector pump to​
stop engine. Notify your supervisor.
