My XM818 makes it home from Little Rock, AR
chgofiveo
Chicago IL
Well it arrives home, but there is a truck stuck in the loading dock, How the heck am I going to get it off the truck?
I know, just winch it on to the roll back, then set it on the ground...No Problem
chgofiveo
Chicago IL
After all that... Im running and driving (cold with a missing windshield)...Now to fix the ONE MILLION other problems...Cant wait!! I will be asking you guys for your help and knowledge as I attempt to fix all the little bugs, but untill then...Thanks for looking, hope you enjoyed my post and
MERRY CHRISTMAS...(Ive got my present early)
ARYankee
33
Benton, AR
Glad to see you got it home. It's even better that you had it shipped too. Have fun with your new toy..... I'm hoping to get another one in the near future.
chgofiveo
Chicago IL
you know you don't have to cut a hole in the floor to fix the spider valve? you remove the tool box and you have much better access.
I tried...The darn bolts wouldnt come out and I was frustrated...It was about hour 12 working on the truck and I really wanted to see if it would run. Im planning on doing some cab modifications, so the hole really wont be a big deal when all is said and done...
Thanks and Merry Christmas
mckeeranger
Eastern Kentucky
The plate on the bottom of the springer seat covers the hole anyway, doesn't it?
Good looking truck. Are you going to use it as a tractor, or do some modification?
tm america
25
merrillville in
nice looking truck glad you finally got it home great thinkin on the tractor -skidloader .it would have broke the rollback forsure without them.my buddy broke the bed frame on a roll back loading his f 350 quad cab with 54s on the rollback backwards .opps snapped the frame right where the cylinders attach the truck hit the ground hard :roll:now you just need to start getting some trailers for it
chgofiveo
Chicago IL
The seat plate sure does cover the hole...you have a good eye! Im thinking of cutting the cab behind the door and extending the cab 8 inches so I can fit my fat a$$ in there a little better. Im going to make the seat air ride (using the exsisting seat) and remove the fifth wheel and add a modified/shortened drop side bed...may put a dump mech on it...Ill keep you posted
M920
30
chama/nm
Nice M818....Good thinking on the unloading! I does look a little cold for the test drive....You know, you could just swap sides on the windshields for now....get at least the driverside covered.....of course this way you don't have to worry about it fogging up....lol
chgofiveo
Chicago IL
The other side was SO dirty from the ride from AR, no windshild was way better...Besides if I swapped it over, where would the fun be?
Merry Christmas Bro
chgofiveo
Chicago IL
Glad you made it home, did you get to use the loading ramp?
James
Hey James
Merry Christmas!
Im pretty sure they used the ramp
Phillips Towing right by the base gave it to me pretty hard for pushing or winching my truck onto the trailer... I wont use em again, thats for sure!
Anyway, all is well with the truck
Thanks Again
Mike
