Name this Trailer
1,540
62
Riyadh, Saudi Arabia
Anyone know the military designation for this 35 Ft Trailer, fifth wheel style military. Formerly a command center trailer, it has 100 amp power box, lighting, paneled walls, battleship door, opening for ac unit, military non directional tires
What do you guys think it is worth in the condition shown by the pictures?
maddawg308
729
Front Royal, VA
Doesn't look in great shape. It's say scrap value. You don't have to scrap it if you have a use for it, just sayin' it's not worth much more than what it's metal content is.
MWMULES
344
DESOTO, KANSAS
Looks like it was part of the Nike system there were a bunch of different ones and usually had a dolly for the king pin and were made to set on the ground. Also Nike trailers have shocks and coil springs on the dolly and rear axle .
jdknech
Jeffersonville, Indiana
I have one like it I got from Redstone last year. It has a steerable axle up front and the same size tires and rims as the M37 type vehicles. The interior is similar so it may be from the same system as the one I have.
there is one of these near me for sale, how does it pull behind your 5Ton? and is the front axle in fact a dolly (and removable) or is it permanently attached? thanks
Sierra51
Aberdeen, NC
Back in the mid 80's I was a Ranger Instructor at Ft. Benning....myself and a buddy of mine re-did an old 1950 radar dish trailer just like this one....used it for a field TOC....put in a couple of double steel bunks, a fold down work table for writing grades and rewired it for lights....pulled it with a 2 1/2 ton International stake body....worked out a deal with a supply sgt. in one of the motor pools on Kelly Hill for new tires....was working on doing some bartering for steel rims....the trailer had original aluminum rims....before we could get the steel ones we had a failure one day while pulling the trailer back to Dept....metal fatigue....tore up the trailer a little, but no injuries....so if you get this and the rims are aluminum....swap out the rims asap for steel ones....
