Need a seat recommendation
stutzcattle
Ohiowa, NE
My deuce has two suspension seats rather than the standard bench seat. I need to add a jump seat or something to the middle to accomodate a third person. I've got two small boys and you can imagine the dilemma we have when one of them gets to have the seat and the other doesn't. Sharing is obviously not an option for them.
I'd love to see any ideas anyone has. Thanks.
1,814
Options as I see it. Replace the springer with a companion seat or narrow a companion seat to act as a jump seat. Don't forget to add a 3rd seat belt. There was just a thread a few weeks back where a member sectioned a companion seat.
steelandcanvas
85
Southwestern Idaho
I concur with Kenny, put the original companion seat back in and add another seat belt. The bolt holes are already there so there's no fabbing to do. Their little butts won't care care about the companion seat being so uncomfortable.
1,814
Too bad you are not closer. I' have more than one of the companion seats floating around in various states of disrepair.
wsucougarx
65
Washington State
I would go back to a bench seat. I added a middle seat belt for my daughter so she can tag along with my son and I. Plus the bench seat affords the ability to put green radios under the seat along with other gear;-)
Crawdaddy
Louisiana
How did you add that seat belt? Just bought a spare and bolted onto the back off the cab. Did you have to drill?
I haven't yet installed it, but I got a long middle lap belt out of a van at the junkyard. I have a springer drivers seat, which has the seatbelt provisions on the seat. That freed up the original center seat belt bolt on the back of the cab, so I'll use that for one side. I'll then share the companion seat belt bolt for the middle and be done.
1,814
There are 4 spots on the hat channel that supports the back of the cab. Each part of your seat belt is bolted here. If you have a springer, there are supposed to be little short belts from the seat to this support. I simply added a third military seatbelt and bolted it together with the left side right belt and right right side left belt. Factory bolts are long enough.
91W350
57
Salina, Kansas
I have some of the original seats and a load of stuff headed to Nebraska. Let me know if that is what you need. It will be bouncing north on US81 one of these days. Glen
steelandcanvas
85
Southwestern Idaho
If you have a springer, there are supposed to be little short belts from the seat to this support...
The springer in my '71 had the short belts attached to the hat channel of the back wall, and the other end attached to a piece of internally threaded bar stock which is welded to the springer. The lap belt is also attached at that point. I would imagine this was done to keep the stuffin' from being squeezed out of you on a rough road, as the springer bounced up and down. My '86 Air Force Deuce does not have this short belt feature, just the lap belt attached to the hat channel.
Prankster
Ponca City, Oklahoma
Caddy Kiddy Seat
I once had a 6-way adjustable Cadillac Eldorado seat in a Chevy Elcamino.
The back folded down which was extremely helpful, and it also had a fold down arm rest in the middle.
The vallure Cadillac seat is very comfortable, and it will outlast a leather one; however, the vinyl seat is better adapted to rain.
