Need a TM# for a jiffy lube
jasonjc
291
Gravette Ar.
I don't know yet. I just won it. GL says the NSN is 4930-00-548-2766. I'm down loading 2 tm's right now but nither one has that nsn on them. They ar TM 5-4930-217-14 and -218-14.
jasonjc
291
Gravette Ar.
I was winning 2 up untill the last hour. Then the battle was on. I ended up with one , for a song. Now if it works or not?????????
Dieselsmoke
CA/NV
Data plate on mine does not list the TMS, but I found them on LOGSA about a year ago using this info Model ENG-3 FSN 4930-935-4451 Made in 1969.
Mine happens to be for sale $500. Missing is the compressor but the pressure pots work fine, I rigged it to use shop air instead.
maddawg308
797
Appomattox, VA
Those are pretty neat. Colemans has a few sitting in the weeds. Very useful, but man you have to have a LOT of stuff that needs to be lubed!
jasonjc
291
Gravette Ar.
I found that the newest TM 5-4930-218-24P has the same NSN as GL has this listed as. I have down loaded it and the -217 which sames to be for an older verson of this same unit. I can't wait to see which one it is and if it all works. :D
KaiserM109
SE Aurora, CO
Jason,
If you're ever up Denver way with that rig stop by. I have some 4x4s that Jiffy Lube doesn't know how to service. I always have to go down under with them and now I have a 6x6 and some trailers! These kids they hire can't concieve that a clutch linkage or steering nuckles would need service. They can't find books on a '69 Bronco, what would they do with a '66 Kaiser Jeep M109?
You might be able to start a mobile lube service. You could go coast to coast and see the country! Just about the time you make it around it would be time for the next lube. It would be like painting a battleship; when you finish at one end, you start over at the other.
jasonjc
291
Gravette Ar.
Now I need to find the TM for the eng on the compressor. It should be TM 5-2805-203-14 &24P. Are these out ther in PDF from??? Also in the parts TM it ref. a DMWR 5-4930-218 ??? any one know what that is???
