Need Cylinder Liner and Parts
steelandcanvas
87
Southwestern Idaho
Recently scattered a cylinder liner in my M35A2 non turbo. Need liner, piston, oiler, rings, head gasket set and pan gasket set. Mechanic said bearings look good, and crank can be emery clothed back into shape. Any direction and leads would be greatly appreciated. I worked hard and saved my money to buy this truck, positive point: wife understands things happen.
OPCOM
29
Dallas, Texas
Yow that is quite a damage level! At least the rest of it seems OK. Forgive my ignorance but how does one remove a liner?
3,150
OPCOM, There is a puller made just for that.
steelandcanvas, If you want to get it fixed now, like fast, White Owl, Memphis or Sam Winers will most likely have all the parts in 1 place. If you shop around, you can find a better deal from lots of different places for the different parts. Since you are in Ca, try Norm and Steve at Antelope Valley, They might have all the stuff. Again, since you are in Ca, UPS will have it at your doorstep in 24 hrs. Just my 2c, since the pan is down, i'd still roll a set of bearings in it.
