Need help with brakelights--- M818
100dollarman
Lucerne Valley, Ca. 92356
I have this semi-custom M818 being picked up by the customer on Sunday. All of the lights work except the brakelights. My guy says he cant find a brakelight switch anywhere.
Can anyone give me any tips on where the switch is, or other things I should look for to make them work?
Thank you in advance for any helpful info!!!
(didnt find any info with a quick search)
Barneyszoo
12
Riverside, CA>
Dont know about a 5 ton but my duice was the sameway when I bought it replaced the switch on the master cylinder got it at NAPA not Gov but worked
100dollarman
Yes- I figure there has to be a switch on either the pedal linkage or the master cylinder. I didnt have time to look today, but my guy tells me that he couldnt find anykind of a brakelight switch anywhere.
Thanks!!!
Barneyszoo
12
Riverside, CA>
aww,Its gotta be there most liklly on the master cylinder, military should have a water proof wire going to the frount end of the master cyl. Keep looking
NDT
7,137
Camp Wood/LC, TX
Check the bulbs! Check the grounding of the lamp-units, both mounting bolts have to make good contact.
100dollarman
Well, I never did find a switch, but got the lights working!!!
Found that the master cyl was low on fluid. Filled it and the brake lights started working!!!
I dont know how or why... but they work now!:-D
Thanks everyone for the suggestions!
jwaller
19
Columbia, SC
the switch is mounted to the drivers side frame rail just behind the master cylinder and hes 2 wires with 1 air line going to it.
