Scooter_Mann
- 0
- 0
- Muscatine, Iowa
I have a fairly new soft top on my deuce. I took it off for two weeks because I was in two different parades... and wanted it off. I had it in the back for a couple of days and it got wet when it rained. I sat it in the garage for about 12 days (if was still a little wet), then put it back on the truck. It went back on just fine. Two days later I drove it on the highway to work (about 8 miles). The black plastic/rubber welting that slides in the track at the top of the windshield started coming loose from the top. A couple of miles later it was totally loose from the top with the exception of the snaps at the corners. The center of the top was blown up about 6 inches as I rolled down the road.
It appears that the top was glued to the welting. What do I need to use to glue it back together? I really need some help with his matter! Thanks.
