Need M200A1 parts
juanprado
2,730
Metairie/La (N'awlins)
Same axle and brakes as a m105. They just used thimbles to dually.
What parts are you seeking? I have an axle off a dolly that shares some of the same components?
Wolfman8345
California
Im building a trailer using the m200a1 frame and want to make sure i can get brake shoe,drums wheel cylinders etc
topo
220
farmington NM
I remember something about the brakes being turned around or different because of the two park brake handles one for each side . I have a manual if want to copy what you need and send it back .
juanprado
2,730
Most of the components of the air over hydraulic brakes are available in the civy world. Parking brake cables & handles might be trickier and military only but I recall a lot of that is on ebay and at various vendors.
I would make you a deal but shipping to the left cost on these heavy items is probably not worth it.
Guyfang
22,307
Burgkunstadt, Germany
Gents, before doing a deal, look at the respective parts TM's and compare part numbers/NSN's. Will not take all that much time, and may keep you from screaming.
Just looked a few things up. Brake shoes are the same. Brake drums not. Then looked at axles. Not the same. You also need to know that there are three different types of "M105" trailers. In the TM for the M105 type trailes, there are two axles listed. One axle fits two of the trailers, the other axle fits the third trailer. The axle in the TM for the M200 trailes has a compleatly different part number then both the M105's axles. I did not look any farther.
Wolfman8345
California
But is there a place to buy the parts, i dont have a problem finding nsn numbers, but i need a place to buy consumable parts brake shoes wheel cylinders drums etc?
