Need new fuel pump for M151A2
m37jarhead
Gilbert, AZ
New to this site. Struggling with the "search" section. Sorry.
The fuel pump on my M151A2 is bad. Where is a good source
for a fuel pump that can withstand ethanol fuel blends?
TNJ Murray has NOS pumps but that doesn't cure the ethanol problem.
Can these pumps be found at NAPA or Autozone type stores?
Got a part number?
Any help appreciated.
Jerry
Aswayze
Martinsburg Wv
I got sick of dealing with the same issue on my M151A1 and adapted a rotary fuel pump to it.
The one I used was a Carter brand part number P4603hd from NAPA. It's a bit noisy but since it doesn't have rubber parts for the ethanol to eat, it's been a winner. No more loosing prime, no more dead fuel pump surprise.
Stagg was going to fit a newer mechanical pump to his A2 but since I have an A1 that's where my windshield washer vacuum pump goes...
nattieleather
134
Cleveland, OH
Take the pump to a good auto parts store. One that has knowledgeable staff and see if they can find a replacement. If memory serves me right (and it may not) a Chevy small block fuel pump may work. I know the bolt up is the same and gasket to block is the same so maybe that will work. Take the old pump in and see if they can find a match.
m37jarhead
Gilbert, AZ
Thanks for the advice.
The NAPA guys down the block have been very knowledgable in the past.
I'll take the pump up there and see what they can find.
Jerry
ODFever
Madness Takes Its Toll...
73
Orlando, FL
Call Rich Miller at Riv-Rad. 251-988-8666. He is honest, doesn't overcharge you, and is there for you if you need help installing parts.
cobra5
194
Stevensville, Montana
M151A2…Airtex, customer part number 021163, catalog number 928M, cost USD43, available at Autozone.
or also usable, but not identical fuel pump for mid 60s Valiant with slant six
Whiterabbit
14
Bristol Va.
I must be doing something wrong, I tried 4 ways to Sunday to look those numbers up and got zip. They still good?
cobra5
194
Fuel Pump
Okay, when I posted this it was a cut and paste for another sites WIKI. The pump you want is an Airtex 60577. Autozone has them for 19 bucks. These are mechanical pumps used on 1960's era Plymouth Valiant. The only difference is that you won't b eable to ford a river with the civilian pumps.
Whiterabbit
14
Bristol Va.
Can't ford a river? Hmmm. Been known to have water half way up the doors on my trucks.
I guess no one makes a rebuild kit for the military ones?
Blake
56
Opp, Alabama
The fuel pump died on mine and I put the slant 6 Plymouth pump from autozone on this weekend since time is getting short for the Georgia rally. For the existing vent on new fuel pump, I drilled and tapped the hole and threaded in a machine screw to seal it up. On the other side, it had the casting indentation that mirrored the hole on the other side. I drilled it out, and then took a brass hose barb, dressed it up with the belt sander, a few drops of jb weld to seal it, and pressed it in the hole. The fording vent will attach as original. Since the civilian pump has a hose barb on the suction side and not a flare fitting, I put together some brass fittings to go from the original double flared hard line to a 5/16 fuel hose. Connected the suction side with the fuel hose. I bent a new line to run to the carb so I didn't bend the original out of shape since the output is to the front instead of the side like the original pump. Nothing original was modified so it can be put back to stock with my original parts when the new military style pump comes in. Overall, a very clean installation.image.jpg
m37jarhead
Gilbert, AZ
I've using the blue "marine" grade of Stabil for some time. This was recommended to me by the Stabil guys at the Barrett-Jackson auction.
This blue stuff is a little more expensive than the red that we've all been using but Stabil claims it's superior. Time will tell. Thks, JB
XChief
Fredonia NY
I used the 1966 Plymouth Valiant Slant six pump. Worked perfectly but the line to the carb points to the right front of the vehicle instead of straight ahead. Tweaking the steel line will solve that.
