Need valvestem for hummer wheels
cdqat1432
Warren, Ohio
Hello, new to the site from Ohio. I recently purchased a m101a3 to pull behind my jeep and then went with the same wheels as the trailer (12 bolt, 8 lug hummer style) for the jeep. Well, while airing up the one tire, it fell over and broke off the valvestem. Where can I find these valvestems? It has a threaded stem that goes through the wheel with a locknut on the inside. It is a fairly large bore, maybe 3/8" with the actual valvestem threading into it. A couple spares would be good because I checked a local tire dealer and the local Caterpillar dealer and neither one has seen anything like it. I checked Cat because the piece resembled one I had seen on a backhoe. No such luck. Thanks in advance.
doghead
4 Star General /Moderator
1,193
NY
Try a local tire shop?
or just Google Humvee valve stem.
Brian1
Albuquerque, NM
Are you still looking for these? I have heard a Hummer Dealer can get them for $35 each and I think that only includes the hex part that bolts through the wheel. The schrader insert is extra. You can get the schrader part from Trail Worthy Fab as cucvnut said.
I recently took off 5 of those bolt in valve stems with the oval hole off my 12 bolt hummer wheels and am willing to sell them. If you are interested send me a PM.
