New Battery Time!
LiqTenEXp
NJ
Hey,
I did some searching around here and tried my luck at the local interstate battery distributor. They had "econo" batteries for 35 bucks each. I picked up 2 Group 31 batteries. To make them fit the box I had to remove 2 of the nut/bolts that hold the shield on the back of the battery box (I have the plastic battery box).
Once that was complete I cut some wood to wedge them in there firmly.
Thing starts like a champ now. For 70 bucks plus tax it was definitely worth it.
I would like to thank George for giving me a set of batteries that lasted me from apirl till now. They weren't supposed to be as permanent as I made them but they finally gave up in the cold.
Before:
After:
Next I have to figure out if my manifold heater is working. Sure doesn't seem to help starting in the cold. I know the pump "runs" aka makes noise, draws power. I was reading up on how to check it and decided I will pull the spark plug and see if I can see a mist of fuel and spark form the plug.
dittle
72
Albia, IA
Since you are up in the cold belt I hope you got the highest Cold Cranking Amp batteries they had.
The cold can sap the batteries, thicken the oil and generally make a deuce hard to start.
Good point WM, I'm sure a lot of guys overlook the CCA rating when trying to find the battery that will fit in the box. I know at the museum we make sure everything we have has atleast 650CCA (standard 6TL rating). I put some Batteries Plus Werker 675's in my Deuce and it spins it over in single digits with ease. I used a very similar setup that LTE did to make it fit, just shimmed a little differently.
LiqTenEXp
NJ
BTW, I had to cut the 4 bumps at the bottom edges of the battery box to get them to sit flat. Only took like 5 -10 min with a dremel.
Mark2X2
Washburn, WI
Hey,
Before:
After:
The best batteries I've used are John Deere Strong Box, they have epoxy anchored plates. That means for off road equipment or Deuces, the plates won't come loose & short out the cell. We run them 3 years in our woods equipment, then just change them out & put them in something else we don't use in the winter, we had one set 9 years in an old JD 450C.
If I was going to run my Deuce in the winter and had a place to plug it in, I would put a block heater like in another post & run cheap batteries and leave the SAE 15-40 oil in it. If for some reason I needed it where I couldn't plug it in, it would have Strong Box batteries & change to SAE 10 oil. Talked to a old Caterpillar mechanic about oil. His thoughts where, more engines are wrecked in running to heavy of oil than to thin.
1stDeuce
15
Farmington, NM
I am really jealous of those plastic battery boxes... My rusty metal box is killing me, and of course, nobody has a line on any cheap plastic boxes...
Mine will spend some time getting to know the sandblaster this summer...
C
