new motor ?'s
snakepliskin
south carolina
hey everybody! of course im new here so ill say hi im joe and get on with the question in case somebody knows about it and can help.
i bought a new engine from gl its a 6.2l from a humvee i think. i bought it because i figured it would be a later model engine and ive read that the later model 6.2s had better flowing heads than the earlier ones and would be a great replacement in my m1009
heres the thing. it looks very similar to the engine in my truck but there are obvious differences such as
no vacuum pump on the top rear of the engine there is an electronic thing instead
also no where to put vacuum lines to the injection pump just more electrics
dipstic tube is different but probably not a big deal because the oil pan doesnt look like it will go in and clear the front axle
i guess its no big deal if the vacuum pump can be put in there but was just wondering if anybody had any experience with these engines
side note -- i want to get an nv4500 in this thing too, will i even need the vacuum pump with the manual trans?
Westech
CPL
6,104
207
cow farts, Wisconsin
ok.. the Engine you got is about the same thing. around 155 hp and that's it. you do not have to change the oil pan but I would if I were you. The vac pump can be installed no problem just take out the RPM sensor. The injection pump is 24V so you will have to swap out the top plate or just the fuel switch in the pump.. its ez as pie. the TPS sensor is a bolt on swap on the pumps , no big deal. With a manual trans you will NOT have to use the vac pump.
southdave
ripley, oh/TDY Lordstown,Oh
you got to do the big swap out, bascially you have to make the new motor llook like the old one. swap the water pump, the glow plugs , and the fuel solenoid ect.. do what westy says he types quicker
