- 2,606
- 2,354
- 113
- Efland, NC
Chemically removing a biofilm is challenging. I would suggest modifying a power washer wand and doing it that way.
If you decide to do a chemical clean you'll still need to do a spray ball and not just fill then tank with fluid. You need fluid flowing across the biofilm for the chemicals to do their best job.
Search for Minncare. Its a hydrogen peroxide and acidic acid solution. Its very effective on biofilms. We use it in the pharma industry on water systems. It won't damage aluminum. It will damage almost any elastomer.
