New to Mep-003A Questions
AIE1
Arlington, Virginia
Hi, recent purchase of a Mep-003A. Super info on this site, still reading threads.
My question, this generator with new batteries, starts and charges. Is it normal for these to charge up to 31 volts for about an hour then slowly drop back down to 28+ or -?
So far every thing about this unit works, have not load tested, outlets will run just about anything I hook up.
Next question; book states to adjust valves after 500 hours, this one has just a little over that with most of that time run my me. Do we have a one stop shop for head gaskets and other mis parts, i.e. fuel filters, oil, and the seal o-rings?
thanks in advance!
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
31 volts is not normal. You probably have a DC rectifier/regulator going bad.
Look at the WIKI article, it has information about a lot of the filters and common parts and where to buy them.
And as an option, I sell spin-on adapter kits for the oil filter.
AIE1
Arlington, Virginia
Thanks for the reply,
Another question, there appears to be a diode, that has been installed in line at the terminal lug where the voltage regulator wires and stator wires connect. Doesn't look factory, was there an MWO applied to these gen's?
TIA!
AIE1
Arlington, Virginia
Maybe I need to explain more!
"A modification work order is the official publication that authorizes and contains instructions for any alteration, conversion, or modernization of an Army end item or component of an end item, which in any way changes or improves the original purpose or operational capacity in relation to effectiveness, efficiency, reliability, or safety of that item."
There is a small device installed in line at the V/R termnal board. Stenceled on the side of the generator in yellow is "Battery Charging Modification Installed Do Not Disconnect Battery for Storage Between Use".
Could this device (Diode)? be causing the voltage regulator to out up to 31V during the charging process.
Maybe I should remove it and see what happens. It doesn't look like an offical MWO due to the electric tape half assed job.
Any thoughts??
TIA
Isaac-1
51
SW, Louisiana
I am not sure on this issue, I think the earlier voltage regulators did not have the diode, but later ones came with one, it sounds like yours was retrofitted. Hopefully someone with first hand experience on these will respond soon.
Ike
