WvGibson
- 0
- 0
- West Virginia
OK, first apology if I posted this wrong, I'm new. I bought a new deuce and have been putting it back together (came with parts just not on the truck).
It is a 1972 w/w m35a2 multi fuel with the D turbo. Military rebuild was 1989. In 2011 all the rubber seals, brake, fuel, and air lines were replaced. The truck had when i bought it, 5,669 miles and 326 hours. Every thing functions and runs well. It still has the fdc in use. I added a dynomaxss muffler from napa and a plastic battery box because the box wouldn't slide out. Then put 250 miles on it. Still runs great.
Here are the minor problems/questions.
1. Horn dose not work. I checked the button its good and good ground there at steering column, but no ground at solenoid. I do have a contentious hot at the solenoid. I jumped a ground to the solenoid and still no horn. I suspect a bad solenoid and a broken wire in the steering column. Where can I get a solenoid?
2. Where can I get a 24v headlight? The low beam on one side is burnt out.
3. Is it normal to have weak breaks? The air pack and master cylinder seems good. It will slide the rear tandems, but the petal has to be almost on the floor. Any suggestions? or is that normal.
Thanks
Thanks
