Newbie needs help with fuel system
71marine
Rome, NY
Hi,
I'm new to the form due to the fact that I just picked up my first M35A2 Kaiser - Jeep 1970 vintage. My problem is that it has not run in 7 years. I'm not getting fuel to the injectors. There is some fuel in the filters. I'm planning to change the filters and flush the line and tank.
Any other suggestions. Does this vehicle have a pump in the tank?
Any help appreciated!!
Tom
BFR
Rocket Surgeon
2,330
42
North Georgia
it does have a lift pump in the tank. these are often dead for one of 2 reasons... one the fuse is shot, or two it's junk.
If my low air buzzer isn't going offI can hear the pump from the cab if the engine isn't running
nattieleather
148
Cleveland, OH
The filters should be full when you turn the switch to on but not start the truck. The in tank pump should fill them.
See if you are getting fuel to the injector pump. I had a duce that had gotten gunk in the injector pump and was so plugged up that it wouldn't run. If filters are full and clear and the fuel is getting to the pump but not out then it's the pump that is mucked up.
On the other hand if your not getting fuel or only partial fuel to the pump then I would check the in tank pump.
It wont hurt to flush all the lines anyway if it's been sitting for 7 years.
3,161
Remove the cover on the side of the pump and make sure the shut off lever moves. It might be gummed up. Push it back and forth a few times with yer finger. nopics
acetomatoco
9
yup and get the 209 series of manuals and the other pertinent ones for the MF, etc and read read read. Don't forget that there are essentially 4 filters on your truck... The screen on the bottom of the intank pump is #1, the pre filter under your alternator is #2 and the "secondary" is #3 and the final is #4. Your intank pump should pee a stream out the bleeder on top of 3 and 4 if all is good... Don't forget to check the mod for Diesel Only....aka the compensator bypass and as the post above stated... the shutdown levers on the side of the IP.
cranetruck
94
Meadows of Dan, Virginia
The filter on the frame below the alternator is also a water separator and must be drained from time to time as should the secondary and final filters on the engine. The screen on the in-tank fuel pump rarily gets clogged.
If you have fuel to the Injection Pump, but nothing to the injectors (no hint of smoke out the exhaust while cranking), then it is possible that the fuel plunger in the IP hydraulic head may be stuck. Check the shut off lever first as stated above.
To free up the fuel plunger, remove the top center plug on the hydraulic head and using a clean metal rod, tap lightly on the plunger.
The plunger is spring loaded and rides on a cam. The cam moves the plunger to its uppermost position 3 times for every crankshaft revolution, so chances are that the lobe is not in it upper position, which would prevent you from tapping it down.
Make sure the fuel cut-off is keeping fuel off while turning the engine over for this job. With a 20:1 compression ratio it doesn't take much to get it to fire.
Bill W
47
Brooks,Ga
The fuse for the intank pump is located at the tank at the top of the pump ( you'll see a wire running to it ) remove the small cover and its right there.
cranetruck
94
The only ground wire for the fuel tank is #79 and it goes from the frame to the fuel pump via the connector on top. This also supposedly grounds the fuel level sending unit and provides a "static" ground for the tank. Check it!
1,161
Wonder what ever came of this......
71marine
Rome, NY
Fuel System help
Well, finally got around to working on the deuce... changed the filters, drained the tank, fresh fuel . No start... lift pump is working , fuel to the IP. Manual says to bleed the #1 injector I'll try that tomorrow. hey Bjorn, where is the fuel plunger you spoke about? Maybe I can try that also!!
Thanks
71marine
Rome, NY
Bjorn,
The exploded diagram does not resemble my inj. pump. is the plunger you are speaking of in the housing that feeds the injector tubes? I removed a plate that was spring loaded and had 3 3/8 bolts holding in place. This was closer to the fire wall on the pump. The piston moved when the master switch was turned on and fuel lift pump came on.I need further help to find the plunger I guess...
