Whitfield
- 5
- 18
- Richmond Virginia
( 8 ) new glow plugs installed.
Repaired missing charge wire from pass alt to rear battery buss. SOmeone had the charge wire run inside to the arear where the dash battery gauge is.
Much of the interior stuff did not work because the black out light switch was blacking them out
Headlight feed wire to 12v terminal on firewall (then on to fuse box) was not bolted to the 12v supply lug at fuseable link.
Headlight harness is cut up... I have one right front park lamp, 2 tail / brake, and one reverse.
Guess i'll be studying headlight harnesses tonight.
Update:
3 Headlight harness feed wires were cut @ coolant resevoir.
Lft Parking light socket was MIA
Female Headlight plug clips needed lots of cleaning.
Looks ike I might be down to just bulbs
(1) headlight
(2) marker lights
(1) back up light.
.http://www.steelsoldiers.com/cucv/27922-wheres-your-license-plate.html
Update:
(1) headlight
(2) marker lights
(1) back up light.
