Just bought this back from the U-Pull IT. Cost $45.00, all steel with rubber coating. It came off a minivan; but needs only mild persuasion with an over sized hammer to lay flat. Question: This seems like an obvious question at that: Should I not plan of securing this to the fiberglass top? Will the torque on the vehicle ream and rip at those holes.
I was thinking about adding a rail piece on either side of the bed- sandwiched between the top of the bed rail and the top. 1/4" steel to build support struts to the rear section of the carrier?
It attaches with 16 bolts on the two 1 3/4" flat padded rails. Bolts into inserts. Think it needs support or can the fiberglass top cope?
thanks,
Ed
thanks,
Ed
