No Brake lights
Warthog
244
OKC, OK
I have a '87 M35A2c with the dual M/C. I have no rear brake lights or rear flashers.
I have checked the following:
The bulbs are good.
The front flashers work.
The rear park lights work
The connectors that I could find are tight
Any ideas?
Thanks,
Warthog
emmado22
168
Mid Hudson Valley NY
are the switches on the airpacks the old style (hydraulic) or the new style (air)? Are you checking for brake lights with the truck running and at full air pressure?
Warthog
244
OKC, OK
I checked the lights with the truck running and the tanks full. Don't know if the brake light switches on the AirPacks are hydraulic or air? How can I tell? They look like standard hydraulic. (there is one switch on each airpack).
Maybe a bad 3 way lever?
emmado22
168
Where do the wires going down to the airpack go? To a round switch on the "end" of the airpack, or is the switch/wires on an airline?
If you have the old style switch, buy 2 each new style retrofit kits from Saturn Surplus... A) it's MUCH safer than the old style, and B) it just might fix your problem.
Here are some other past threads that will offer more help.
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=16625&highlight=airpack+switch
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=18375&highlight=airpack+switch
Warthog
244
OKC, OK
Well the problem is solved. It turned out to be multiple issues.
To answer the previous question, the switches are attached to the air lines.
Rechecked the bulbs. One was good and the other tested good but when you wiggled it it would fail.
Tested the airpack switches and they where good.
Checked the flasher unit and it had a rusty gound. Tried the flashers, the replaced flakey bulb would work but the good bulb wouldn't. ?????
I had a turn signal switch from my M715 project. Changed it out and everything worked as it should.
So to recap, double check your bulbs, check your ground and test the turn signal switch.
Thanks for everyones help.
Warthog
dabtl
Denton, Texas
Bjorn would be proud you checked the grounds. I was going to suggest exactly that. It is a good idea to contact Grainger and order new internal/external star washers in any case.
