jarrettpcfr
- 0
- 0
- salem, al
got my m1028 from warner robins. got it home, submitted the sf97 and went to work. seems the glow plug card is not working properly, kept cycling on and off non stop, can the glow plugs be used without this, i got plenty of toggle swithches, took the card out and the truck still cranked right up. the transmission leaks from the governor plate, easy to tell with trans fluid on the tailgate from testdrive. i hope its the governor plate, i wiped it off while it was running and kept coming out of there. and the driveshaft is bent, very little, barley visible except with a 4 foot level. if someone could point me in the right direction for the glowplug bypass (thread attachment) i would really appreciate it. looked for hours, i want to make sure i get the right wire.
