No lights
mgpm35
Maryland/Pennsylvania
Working on an M35A2 and find that the service lights will quit intermittently. The only pattern I've found is when the signals are on for awhile, all lights will go out. It is most common when using the flashers. I'll be running uphill, under 40mph, flashers on, lights on, and they'll go out. Happens also when truck is parked, running, lights & flashers on. After a minute or so, everything comes back on.
Any ideas? Flasher unit?
Thanks for any help.
OPCOM
27
Dallas, Texas
The connector at the turn signal switch was loose on mine causing a similar isue. Must have vibrated unscrewed. Maybe the connector behind your light switch?
mgpm35
Thanks M35TOM and OPCOM. It would be nice if it's that simple. I always have a rough time when it comes to running down electrical issues.
When I check it out, I'll post the results.
