No power to start button
L7apk
UK
After a 2 hour drive yesterday , I came to start my deuce today and nothing happened when I pressed the starter. The ignition switch powered up the pump and the guages came alive , but there was no reaction from the starter switch. I tested the continuity of the switch which is fine, but no power to the switch. I ended up starting it by shorting the starter motor and it started fine as usual.
Could this be a broken wire or does anyone have any other ideas?
Any likley places a wire could have broke?
I'm needing a bit of help with this one, Please!
Boatcarpenter
Marlborough, NH
# 74 comes from # 27 from the Ign. Sw.then to the starter button and then from there to the starter relay. # 27 comes from the B terminal of the Ign. Sw. Should be very short wire. Either it is broken or the Ign. Sw. is not powering it for some reason. Get out the multimeter and poke around :D Have fun under there.
BC
Manstein
Chaplain Emeritus
331
Cartersville Ga.
Mine did the same thing when I picked it up from GL when I shut it down at the first stop. That starter relay that is bolted to the engine block was the culprit. I bought a new one from Memphis and it failed within a week. Replaced it again and it failed again. I bypassed it rely on the soleonoid on the starter. No problems since.
Boatcarpenter
Marlborough, NH
Manstein, happened to me also, but L7apk said he was not getting power to the starter button. "but no power to the switch.". At least that is the way I read it.
BC
L7apk
UK
m-35tom said:
the power that goes to the low air buzzer switch is the same power that goes to the start button.
Ok that might help matters.
Can anyone confirm the power comes off the alternator to the starter switch. Is it the smaller wire on top inbetween the 2 larger ones
burt gummers
port allegany PA
my button lost power once. the ground cable that goes from the starter to the frame went. it happened just as yours did i pulled into westfolks house it cooled and i shuter down. hours later came back and hit the button and nuthing. ended up starting it via a short and got it home to change the wire. just another thing to rule out. good luck
L7apk
UK
Yes , I have now traced it to the starter relay. :D
sorry I gave you some duff gen in the initial post, there is power to the switch :oops:
To bypass it , did you simply undo the small wire on the top of the relay and connect it straight to the larger wire underneath the relay. On the wiring diagram Boat carpenter supplied it would be wire 74B removed and connected to 14 or 214.
Is this a safe fix?
