Noisy fuel feed
Retiredwarhorses
4,482
Brentwood, Calif
Just got the new M932A2, I noticed where the tank selector valve assy is, it makes a rather loud ticking noise...when I grab the lines under the cab that is where it is coming from...my 931A2 does not....I noticed that the noise seems to come and go....more come then go.
anyone seen this on any of there trucks?
if I rotate the selector to the other tank it goes away half way though the turn and then starts back up....
Suprman
703
Stratford/Connecticut
Maybe you hear the fuel return at idle and when you switch tanks it goes to the other tank. The pump is always pumping when the engine is running it returns unused fuel to the tank.
Retiredwarhorses
4,482
Brentwood, Calif
Valve is noisy regardless of what tank is selected....the lines pulsate...but so do my m931.... Just no noise...it's quite audible...if,not for that, the 8.3 just purrs.
Suprman
703
Yes you hear the fuel return. The fuel pump is still pumping it returns unused fuel to the tank you can hear it on some trucks more than others. It is less noticeable with a fuller fuel tank.
