non slip yoke 208?
rustyolred
Denton, NC
Is ther such an animal? If not is there a reputable sye that is not a hack and tap? Haven't broke the slip yoke on the CUCV yet but did on my 81f150 with 4.9 I6 and 4 spd trans. Also only 33" tires and 4.10 gears.
jdemaris
I've seen places that sell "kits" now and then that will fit any 208 or 241 transfercase. All it comes with is a yoke and a bolt. You have to drill the output shaft yourself and tap the hole so that yoke can get bolted on. Then supply your sold drive-shaft with its own slip-spline setup.
Using factory parts, you'd need a different output shaft. And, the 208 uses a different output shaft, speedo gear, and tailshaft then a 241 uses.
In regard to the Dodge transfercase with the fixed yoke - it has different input splines then the two GM setups.
Cucvnut
51
Carver, Oregon
ODdave
lansing michigan
That is why you only use the output shaft and the tail housing from the dodge:doh:
Dodge used both 208's and 241's in the ram chargers. This is gonna be your cheapest option.
The ford one will NOT work. the tail shaft casting is differnt.
