not cranking
cucvdonk
va
My glowplug relay went out and was using ether or pure silcone spray to start only if needed the truck while waiting on new one to arrive. But the other day was getting wood and the front battery grounded out on the battery hold down and now it wont even crank. checkedthe fuses they are good. how do i check the starter relay and whats the easiest way to check the solenoid. or is there anything else i should check on it first? I am goingto go and get the batteries checked make sure didnt kill them.
pigfoot63
Gainesville, Ga.
Best guess check you ground wire located on core support in front of your front battery, check all your fusable link wires. If you choose you can bypass your stater relay with a length of heavy guage wire at least 12 ga. Grounds are very important on CUCVS. Hope this helps
cucvdonk
va
Do the lights turn off when hitting the starter? You could of taken out a cable
When you say hit the starter you mean turning the key like your bumping it over? I will have to check that when I can get some one to help me there. But i will let ya know for sure
cucvdonk
va
Oh and I noticed that generator one is the only one lighting up in the dash generator two light isnt coming on.
cucvdonk
va
How do you go about bypassing the starter relay?
pigfoot63
Gainesville, Ga.
Jump betwween the two large wires on the starter relay, going from memory I think one is purple and the other is red. Remove the wires from relay before you do this. Key switch should be in run position. A remote starte switch works great fot this.
trooper632
Utopia, TX
On mine, thought both batteries were good, lights would come on bright but would not crank, changed out starter relays, changed out the starter nothing. Come to find out the front battery was just plain DEAD. Put a new battery in and it started right up. Check both batteries first before you do anything else, it will save alot of time and trouble.
cucvdonk
va
Thanks I took out the batteries earlier and going to run to town and get them checked now. Maybe that will be the answer to my problems.
