- 1,889
- 1,116
- 113
- Paris KY
The speedometer is controlled by a "Drive Gear" inside the NP208 transfer case and a "Driven Gear" mounted inside a removable sleeve on the side of the transfer case, to which the speedometer cable is attached. GM offered (and still offers) various teeth counts on both "Drive Gears" and Driven Gears" so that the speedometer is correct to the ground speed, based on different combinations of "Drive" and "Driven" gears.
Does anybody know which speedometer "Drive Gear" GM installed in the CUCV NP208's? The "Driven Gear" is easily changed from outside the case, however the "Drive Gear " can only be changed with the transfer case disassembled. If we knew exactly which "Drive Gear" was used originally, we can then easily determine which "Driven Gear" to use to correct the speedometer based on tire size. It will only be Blue, Red, or Gray. Only someone familiar with the NP208's internals would know this. If this can be determined, I will invest the time to develop a chart for correct speedometer readings based on tire sizes.
As a follow-up, the Blue "Drive Gear" is 18-teeth, the Red "Drive Gear" is 17-teeth, and the Gray "Drive Gear" is 15-teeth.
Here are a couple photos of how the "drive" and "Driven" gears go together. The first photo is a cutaway image showing how they mesh together in the transfer case. The second photo shows what they look like laying on a table.
