BugEyeBear
- 3
- 0
- Eastern Georgia
More on my recently acquired '71 M35A2....
I was poking around under the hood and noticed that the 2 rear mounting bracket bolts for the IP were quite loose (not even finger tight... in fact they had backed off about 1/16"...)
So I grabbed some wrenches & tightened them down.
What is interesting about this is that the IP was recently replaced with a new one. So this probably means that "Joe-Mechanic" did a sloppy job at the install and failed to tighten everything up!
This caused me to doubt the tightness of anything that had been recently repaired/replaced, so I spent a couple of hours putting a wrench on anything that looked like it had been recently touched.
I wasn't surprised to discover that many of the recently touched bolts, hose clamps, fittings, etc. were NOT as tight as they should be. & many were just plain LOOSE! My air horns were VERY LOOSE, one of them was only half way screwed in, & the other was cross-threaded & only held in by 1/4 of a turn! It fell off in my hand!
Not all of the bolts were loose, but enuf were that I'm glad I spent the time checking & tightening.
It is worth noting that ALL of the old stuff (that hadn't been touched in awhile) was plenty tight....
Must have been recently serviced by "Joe-NEWBIE-Mechanic", or someone with no upper body strength!
Hope I didn't miss anything VITAL!!
Guess I'll find out!
