Nv4500 swap question
dstang97
30
Clover, SC
I have a 1996 nv4500 out of a k2500 350 gas jobber. The only thing I can't figure out is the hydraulic line. What did you guys do to adapt a internal slave hose to a 86+ master?
southdave
ripley, oh/TDY Lordstown,Oh
Brake line and compression fitting..Heads up OD dave gave me this info the master is a tad smaller bore diameter than the external slave for nv4500.. so bleed well and adjust your focrum ball accordingly.. if it stop raining I can get a pic
dstang97
30
Clover, SC
I tried PMing Dave but has not been on in a while. My clutch line is flexible plastic and stainless steel braided. I can't find one person that has done this swap using and internal slave.
southdave
4spd master to 5 speed slave
SORRY I have to get sleep the I have external slave from a 96 forgot to read carefully. Ok I remember looking for solution for mine. On the net , A guy/ company made a wedge to mount the 5sp master to the sm465 pedal assembly.. maybe this will work?
http://www.novak-adapt.com/catalog/clutch/kit_hcrc.htm
Yeah, mine is the same I cut the flex section out the set used a borrowed flare set made the connection acorrdingly.. if still need photos let me know. 923 photo dump 026.jpg923 photo dump 023.jpg923 photo dump 027.jpg923 photo dump 023.jpg
rlltide12
Alabama
The way i made mine was buy a stock 1993 hose, cut it up and use only the steel tubing portion, flare brake line fitting on it, and had a custom hydraulic hose that went from inverted double flare at the steel line to bubble at the 86 master cylinder. Very similar to southdave except i used an 86 master rather than the newer master.
