Barrman
- 2,172
- 113
- Giddings, Texas
I was flying along at 55 mph or so in the Gasser the other evening enjoying the mechanical noise when a loud thunk came from under the hood, followed by another and then a really odd vibration. In goes the clutch and the gauges get checked. Volts still in the green, oil psi normal, temp right at 180 and air stable. I shut it off and coasted down to about 5 mph. Popped the clutch out in 3rd gear and it fired right up, gauges go to normal and the odd vibration is still there. Nothing smells funny and the lower the rpm, the less the noise/feel from under the hood. We idle the mile or so home and I am convinced the water pump has commited suicide by the time we get it parked. I pop the side cover with it still running and the fan is still spinning, but the noise is from that area. I shut it down and crawl on up to look. No play in the pump shaft, coolant on the block behind the pump and I am convinced the pump broke.
I go look at it the next day and a fast check shows the radiator still full and the alternator belt really loose. While I am trying to figure out how it got so loose, I realize there is only one belt instead of two. Well, there is my problem. When the belt let go, it hit my "triple failure part", the water cooled air compressor, coolant feed line and moved it just enough to cause a leak at a fitting I can see, but not get a wrench on.
Anyway, I need new belts. I put NOS belts on it 2 years ago and this is what happened. All the belts I have left have no numbers on them. The parts book gives these numbers:
Air belt- RC-1861 M5
alt belt- RC-1030 A7
These numbers of course are 60 years old and useless. I know I could take my remaining belts into an auto parts store and play "Lets see what looks closest." I really don't want to do that. So, does anybody have the proper numbers for the wide V belts on a Gasser M35?
Thanks.
Thanks.
