OD Green Paint?
Karl kostman
857
Fargo ND
I have bought many can of OD green camoflage paint by rustoleum I get it at Fleet Farm the color is a very flat OD Green, it does very little to get rid of rust BUT if your surface is clean and prepped (no oils etc) it wears very nicely, they also have it available in a flat black!
KK
jmassenga
AK
I've bought rattle cans here many times over the years. PAINTS Right colors, sprays well. I used about 3 cases of rattle cans in 24087 for my M37.
nattieleather
135
Cleveland, OH
Rapco makes the rattle cans on site (unless Mark lied to me about it) so the paint you get in the rattle can is the same paint you buy in gallons. So the color is the same. I rattle can paineted a M151 a few years back and it looked great.
Docter
Smyrna, Delaware
hey all, i was wondering about the right paint for the m-37, I know at the time the army was doing the semi gloss thing, my resto is to be Viet-nam in country look and i would think semi gloss would not be kept on. I guess the rattle can flat would be good but like i said i am trying to set it up right.
any thoughts ?
youres at arms Doc
WarrenD
9
CT
For Nam, use 24087 semi-gloss. Make sure it is the old FS 24087 as the new FS 24087 is noticably lighter, yellow-brown compared to the FS that was in effect in the sixties and seventies. For a close match using the modern FS, use 24084. I used Randolph 24087 on mine and it looks right to me. I got my rattle cans from Peter DeBella Jeep Parts and he has gallons also. I called Randolph and verified it is true 24087 and also cross references to the modern FS24084. Just be aware that rattle can paint doesn't have hardener like you would add to paint to be sprayed thru a gun so even when cured, the paint is a little soft, ie, scratches easily.
Karl kostman
857
Fargo ND
Today I found out how NOT to go for a small amount of paint! I am painting an S280 for the bed of my Deuce and wanted the color to match my Deuce, today I went over and picked up the paint, I have to add the hardener just before I spray it, its a PPG paint and it was just under 200.00 per gallon I got 2.5 gal. sprayable Good Grief!
KK
Woodsplinter
Phoenix/AZ
I've been using Aervoe paint with very good results. Rattle cans and gallons are the same paint- no hardener needed but cures hard. Comes in all military colors. About $39/ gal, $5/can
