Oil leak on engine
Wildfire073
Terre Haute, Indiana
I have a M-274 A5 with the 2 cylinder engine. I have had oil leaking from the area of the rocker arm covers. I resealed the covers, but still have an oil leak. What else in this area leaks or may need a new gasket or seal? Thank you.
crankshaft45
Ortonville, MI.
Try posting this on G503.com, there are some excellant mule mechanics there who might be able to help you.
you might also give Bill Watson a call in North Carolina, 1-336-697-4020, He is very knowledgable and eager to help.
lilreddodge
Ashland, Ohio
You might want to look around the fitting that the oil return line attaches to. I have found that the head will crack here if the fitting is not screwed in properly. It will look like the oil is coming from the valve cover, but it really is running out of a crack in the head around the fitting.
MuleMac01
Military vehicle collector
135
Las Vegas Nevada
No deep scratches? No deep cuts in the metal?? Did you take off the old gasket that sticks on to the steel? Screws nice and tight?? other then that you might need a special gasket because i use Bill Watsons and they work just fine for me.
