Cucvnut
- 75
- 48
- Carver, Oregon
ok silly question the oil pan on a 6.2 is steel correct ?
really? i have the same truck. not enough room?
so what happens when you flex the springs? does the arm go in to the engine? I think you need to rethink your steering set up. If its going to hit the pan something is not correct.
Sounds like you are opening a whole new can of worms. that oil pan does not have a whole lot of extra swing room on the inside, as I'm sure you realize, but to start cutting and welding on one to clear x-over steering is not something I would want to tackle. I have x-over steering on one of my M1008s with 52" springs mounted up front that came out of the rear of one of my M1009s. They have a lot of flex, and the only thing I had to mod was the cross member of the frame. Anyway, good luck with that. You'll have to let us know how it works out for U...
here is a few pictures of my build. i think this shows i know what i am doing and them someare you useing crossover steering?![]()
I thought High-steer was where you removed the tie rod from being low and in front of the axle to going in front of the steering arms by using high-steer arms with a single hole on the driver's side and two holes on the passenger side. Here is a link to a typical kit: D60 high steer kit for kingpin axlesits not cross over i have that all ready i dont think you understand what i am talking about. high steer is where the drag link goes behind the axle and the tie rod is still in the normal spot of the cross over steering set up. if thats something you dont want to takle thats fine. but me on the other hand thats why i am looking for a spare oil pan so i can mock it up befor i start cutting mine up.
