acme66
- 9
- 0
- Plains, Montana
What if we approach this another way. What about a tank, pressurized from normal engine oil pressure separated from the system with a 24v solenoid and a in-flow one way valve. When you go to start the solenoid dumps and it shoots a measured volume of oil through the system. Whenever the starter is engaged the solenoid is open. A separate one way valve to refill from engine pressure. I see that idea as working and not being a massive project to build. Be nice of the solenoid was on a timer, say open for 15 seconds after trigger. Sounds more compact with less opportunity for failure. I suppose even a good one way valve would leak down slowly but most of the time it would be there. I envision something the size of a fire extinguisher mounted to the firewall near where the ether sits. Just one line ported into the motor leading to the 2 valve manifold at the base of the tank.
Ken
Ken
