Glider
- 155
- 43
- South Pittsburg, TN
My oil pressure gauge went to full pressure with switch turned on but engine not running and stayed at full pressure with engine running. Turn switch off goes to no pressure. It was this way when purchased and I have put about 5000 miles on truck. I ordered a new gauge and installed it. I also cleaned connections when installing. The new gauge shows no pressure regardless of switch position or if engine running. Im a little confused that the 2 gauges had opposite results. If results were the same I would immediately look at the sending unit. Has anyone ran into this problem? I also have done the grounding kit. All other gauges operate correctly.
