Oil Pressure Gauge
1986Blazerk5
Brighton,MI
Im adding a oil pressure gauge tommorrow and i am planning on taking the sending unit out and replace with the sensor from the oil pressure gauge are they any problems with doing that besides that the oil light will not work, but will the sensor hit anything or mess with the vehicles performance. is there a way to hook up a electronic gauge using the exsisting sensor or should i go the other route with the mechanical
Thanks
Westech
CPL
6,104
212
cow farts, Wisconsin
A gauge mess with the performance? No there guy your safe. You can NOT use the OE switch to run a gauge, that is a on off switch it does not send any pressure signals. If you would like both the light and your new gauge to work go to the hardware store and make up a "T" fittings using brass fittings or there might be another place to tap in to the oiling system for your new gauge. Look around the oil filter adapter (oil cooler lines where they go in to the block) for a place to tap in for the gauge.
I would try to run both, you will see that big red light go on before anything else. Its nice to have both.
pinbill
denver, co
I tee'd into the brass valve located on the drivers side top of the radiator using a mechanical gauge. There is a picture somewhere on this site you can find if you dig for it. It worked out nice for me, the fittings from the gauge hooked up right, and with the valve you can turn off the gauge if you need to. (although I don't know why you would)
Here is the thread:
http://www.steelsoldiers.com/cucv/14547-m1008-gauges-2.html
Also if you want to add a temp sender the place to do it is in the next picture. I had trouble with the sender located in the block off plate in the rear of the motor. I got accurate results in the drivers side front of the block like in the picture. Also it was easier to get to.
Bill
