datsunaholic
- 3
- 0
- Tacoma, WA
OK, photos are up.
You can see the residue firefighting piping systems, brackets, etc everywhere.
Note the gray dash pad, obviously a replacement. I got a little concerned when I looked at the Army Registration number and found it didn't match the reg number on the dataplate... worried it might actually NOT be a M1028, as the door is the only place that explicitly states that. The reg number on the door and dataplate were only one digit different though, so I ran the NSN off the dataplate and yes it is an M1028.
While it's really too fuzzy to see, there's a pipe fitting that's not connected to the fuel pump. it's bent back out of the way, and a hose in its place. I think that's the main fuel line from the lift pump to the injection pump.
Yes, the cord hanging out the front is a block heater.
As you can see, it's sitting on civilian wheels, with 33s. Tires have fairly good tread.
No spare, no jack, no lug wrench, no spare tire carrier even.
