Original bed for dump conversion
37
45
Iran
Hello everyone
I bought one M35A2 recently and decided to convert it's bed to a dumper. So people in my country said the original bed is too weak for dump conversion and it's worthless to make it stronger.
I want to know are they right or wrong ?!
And if I want to make it stronger , what should I do
Thank you
gringeltaube
Staff Member
2,260
Montevideo/Uruguay
.... the original bed is too weak for dump conversion and it's worthless to make it stronger.
First may be true; second, not.
Check out this post (in the dump-conversion compilation thread)...
Some of the pictures there showing the reinforcements added to the bed sub-frame. (successfully tested, up to almost 10 tons...!)
Adding two more pics, of that building process:
All that because a single telescoping cylinder was used. If you choose a scissor lift system, the forces are better distributed, so less reinforcements are needed.
tobyS
815
IN
True, there is a lot less reinforcements in a deuce bed, but it is not "worthless" to reinforce. I would use additional bed frame rails myself to add some strength and gain a few inches for a scissor. And if your deuce is typical, it will have welded sides that give it much strength too. For the cost, a (battery operated) scissor would seem to be a good addition.
45
Iran
Hello
Thanks a lot dear gringeltaube and tobyS ;)
I want to keep the original look of deuce, so I like reinforcement of the original bed more than making a shop made dump bed.
How much load can deuce carry without any damage to it ? (I know it has capacity of 2.5 ton offroad and 4-5 ton onroad) But here in Iran people load the poor deuce more than 18 tons !!! I don't want to hurt my deuce because I love it :)
Yes my deuce is a typical M35A2 with winch.
some pictures of my deuce
Thank You
37
45
Iran
Wow, Load and drive a Deuce in Iran at 18ton.........................
Golly, Our guys build good stuff!
Well, spring shackles fail and dogbones twist right off.
I guess they got a lot of our stuff.....................
Proudly Made in USA :cool:🇺🇸
Here people load 5 ton (m816) over 30-40 tons !! They are crazy !!
I think Iranian people just take attention to the number of wheels of Deuce ! they don't care about it's factory capacity ! but not me , I care about Deuce just like my other American cars .
tobyS
815
IN
I'm not saying they are weak, but that the springs and dog bone suspension is not as robust to take an overloaded condition like when new. Be prepared for a fail by having some suspension spare parts, if you can. Putting a dump bed on it will bring even more stress transmitted to the frame, so dumping a heavy load will be big potential to twist.
My m35A3, which may be GK's vintage frame, had enough surface to surface rust at the trunion mounting to take away 50% in my opinion. His trucks frame is same vintage. Here is a photo of my 4x4 but you can see the frame plates I added...an 11x3x1/4. Look for rust between the trunion reinforcement and frame.
I don't see the bed itself as the weak link, but the hinge and frame of a cheap scissor. Go heavy on frame reinforcement or not at all.
