- 2,143
- 101
- 63
- Maine USA
My 86 M1009 snapped the crank a while back so I purchased a 1993 GMC mini bus with a 6.2 showing 92k mies. I drove it down the road a couple of miles and it ran well. So a year later I transplanted the bus engine and now have a question concerning the cooling system. I had the radiator shop clean and repair a small leak in the radiator, new oem thermostat which I tested and works fine . Tried a new cap and one from my current daily driver with same results. Also appears to be a newer water pump. When the engine starts from cold there are large amounts of bubbles and coolant overflowing from the radiator(cap off)and some what appears to be a vapor. Install the cap and it starts forcing bubbles in the overflow tank and all the hoses are super hard . I can only suspect a head gasket is bad but there is no oil in the coolant or coolant in the oil. Also it can sit for a week and when youn take the cap off there is pressure behind it. I would think if a gasket was blown it would leak down. I can't smell any coolant coming from the exhaust either. Any thoughts appreciated.
