overcharging all of a sudden
84cucv1ton
New Jersey
my m1009 is now all the way right in the red. changed nothing under the hood. so i have no idea? could something be failing? what to check for?
thanks
Wartburg
Knoxville TN
My truck did this about a month ago. The Genarators have a voltage resister. I took mine to a local altanator repair shop and they fixed it for $30 bucks. Before I went to the altanator shop, Autozone tested it and said the good one was bad and the one that I ended up getting fixed was good. testing one with a external ground is different. It should be producing 14.2. and mine was pumping out like 17. If they are over charging it will cause stress on the rest of the system.
319
Lieutenant
3,347
58
Michigan
Don't rely on the voltmeter on the dash, always check the output at the alternator, or use the STE/ICE if it's available to you.
1,189
A volt meter is fine.
STE/ICEStandard Test Equipment Internal Combustion Engine
The STE/ICE is a military test system(kinda like OBDII).
1,189
it is, I said "kinda"!
the vehicles are prewired to a central port, to collect data. You connect the STE/ICE to that port to read the info.
319
Lieutenant
3,347
58
Michigan
The voltmeter I refered to above is the dash mounted one. A hand held volt meter can be considered more accurate.
