Parking brake won't hold in reverse
Apex02
Tx
Maybe this is a dumb question but does the parking brake not work when the shifter is in reverse? I had the truck off, e brake on, and the shifter in reverse and had to chase the truck down the driveway to stop it. Seems to hold the truck fine in neutral and drive
DCIV
Morristown, TN
Don't think that matters. My parking brake was about worthless when I picked up my humvee, suuuuper easy to adjust. Just with the brake released, turn the top part of the brake clockwise, check it every so often, when you feel it's about as hard as you can to pull up then it's set. The gear selector shouldn't make a difference.
Havok
Boston/MA
I recommend checking it every month or so. It seems to loosen up over time.
Sent from my XT1650 using Tapatalk
jasonjc
291
Gravette Ar.
Brake don't hold as good going backwards as forwards. I had a platoon sergeant that would back off the knob on the brake handle. He thought it was a tension adjustment for the handle not the brakes.
riderdan
20
Central Kansas
That's why you should use some kind of wheel chock.
Definitely good advice. I don't recall ever parking one unchocked while I was in the service and I continue the practice now that I have one of my own. Since there's no "park" on the transmission (and thus no parking pawl to hold the truck) it's really not a good idea to park on even the slightest grade without a chock. I do occasionally skip placing it if the truck is against a parking bumper that's downhill of it, but even then I'll often chock a rear.
If your 5600 lb humvee rolls away when you're nearby, you might be able to catch it. If it rolls off while you're not there, it might smash itself, another vehicle, or even worse, some kid.
Apex02
Tx
Got it. I'll check this. When I tighten the knob all the way the brake won't set so I guess you can over tighten it. I'll keep an eye on this going forward. Thanks for the advice
