Part # for Selectro Hubs
ken
27
Houston Texas
Mine don't have a # on them. But the paperwork when i bought then list them as MTF250LH. I bought them from botyce equipment and i don't know if this is boyce's # or selectro's. Hope this helps.
1,827
RE: Re: Part # for Selectro Hubs
Even though I know Arthur and consulted with him of the rear axle lockout, i doubt that he would share the part number with me or anyone. I am hoping to score a pair of used Selectros despite their seal design. I'm not normally in the water and don't have a problem repacking if I do go in the water. I just don't care for the appearance of the superior Ouverson hubs.
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
Re: RE: Re: Part # for Selectro Hubs
OK, I understand...
Sorry, a bit off topic now: I just don't like it to spend a lot of $$ (+ 80% shipment&import taxes!) for a product with obvious design flaws that could have been corrected at the factory.
Not only did I have to retrofit them with thicker O-rings and special lube, also looking at the internal components, they seem to be more the size for a HD 1 ton and not a deuce!
Maybe it's supposed to act as a fuse...? I wouldn't use them on the rears! Only the massive and (too) heavy steel spacer will last forever, despite some rust... No, thanks!
Soon i'll be buying Os. (std. version). Than I can really compare and let you all know.
Regarding appearance I wish I had the exact dimensions to know how far they stick out...??? I think that's the only disadvantage???
Gerhard
1,827
RE: Re: RE: Re: Part # for Selectro Hubs
Gerhard, in my humble opinion, that is the only disadvantage of the O's. Other than that they are a fantastic set of hubs.If I were running singles and wider wheels I would be all over the O's but with stock tires and such, they stick way out. Good luck and if you don't mind, report back on the side by side comparison.
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
OK, thanks Kenny.
Yes, they will be used on a "singled" truck, this time with 14" wide tires on 12x20 custom wheels. So there should be around 4 inches before they start sticking out.
BTW, if it wasn't for the distance, you could have my S. real cheap...! :)
But I'm positive you'll find some soon.
Good luck!
Gerhard
1,827
No, that sounds like the 11166-01 hub. Should be 16 spline 1.66 or 1.61 (can't recall) dia.
jatonka
111
Ephratah, New York
Kenny, my understanding is Mile Marker bought Selectro and discontinued the Selectro Hub line. I can get the Selectro part number if you really need it. PM me. John T
