Part No for Double Check Valve 6
PureMayhem
26
Houston, TX
I have been through P2P and the TM's. I can find the WM to replace it but cannot find the Part No. Is it the same as DC-4? Does anyone have it?
Swamp Donkey
The Engineer
123
Gray, GA
Page 256-2 in the latest -24P-1 Parts Manual
NSN 4820-01-478-4650
P/N N20954A (Haldex)
Which crosses to:
Haldex KN25060
Swamp Donkey
The Engineer
123
Gray, GA
I have several. How many do you need? Also curious as to what symptom(s) you had to diagnose this valve as the problem?
PureMayhem
26
Houston, TX
Thanks for the response. It turns out I have the Feb 1999 revision of 24P-1. I have downloaded the current revision and there it is. Thanks again.
PureMayhem
26
Houston, TX
I am not sure if DC-6 is the problem yet. I have air exhausting through the air intake stack after shutdown and have traced it to the hose that comes from the treadle valve. I have ordered a rebuild kit for the treadle valve. Looking at P2P the next 2 valves in line are DC-6 and DC-2. I could find the PN for DC-2 in my older TM 24P-1 but wanted to know the PN for DC-6 in case the rebuild of the treadle valve didn't work.
Swamp Donkey
The Engineer
123
Gray, GA
DC-6 was added as part of the ABS system MWO, which is why it doesn't show in earlier manuals. The ABS manuals are also in the TM section and might be helpful.
