Parts Help with M35A2 Signal Control
rwminck
Florence SC.
$T2eC16hHJHwE9n8ikMw8BP+2r9mKtQ~~60_39.jpgMy drive side front turn signal is not working, I have been looking for the fault and believe the problem is the signal control assembly on the column. The tan assembly is the one that is on my 1972 AMG M35A2 Will the green assembly fit my truck? Thanks
gimpyrobb
dumpsterlandingfromorbit!
27,787
773
Cincy Ohio
As stated, yes it will work for your application. Have you tried jiggling the wires going to the signal control? My first 6x6 had these issues and it turned out to be a loose wire in the harness, not the controller.
rwminck
Florence SC.
Thanks Guys, The wires between the plug and the crimps at the plug are in bad shape, so that will have to be repaired, and the controller housing has a 1" crack, so I am going to replace it too. Thanks again!
