Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
My drive side front turn signal is not working, I have been looking for the fault and believe the problem is the signal control assembly on the column. The tan assembly is the one that is on my 1972 AMG M35A2 Will the green assembly fit my truck? Thanks
As stated, yes it will work for your application. Have you tried jiggling the wires going to the signal control? My first 6x6 had these issues and it turned out to be a loose wire in the harness, not the controller.
Thanks Guys, The wires between the plug and the crimps at the plug are in bad shape, so that will have to be repaired, and the controller housing has a 1" crack, so I am going to replace it too. Thanks again!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
