jdeoliveira74
- 3
- 0
- wilmington nc
So I did some sound deading today used the peel and seal on the floor of the m1009... Its makes a big difference! much quieter. I have worked with dyno mat before its real close
I installed it today and i didnt notice it at all to be honest and it was pretty hot today. Did it in the sun for a good warm surface make sure it is there forever.how's the smell? my readings lead me to believe that the asphalt based peel and seal will stink in the heat...
this also comes in a 3' wide roll they just didnt have any instock. So it was an experiment anyway. I did the entire back for 32.00. Your talking about icy weather barrier Its the same minus the aluminum top coat. should be fine from what I have seenThanks for the picts. Not quite what I was thinking of. Looks like it worked though! I'm thinking of using the ice barrier that you put down before shingles or roof tin. It comes in 3 foot wide rolls and sticks on contact with anything. Not sure if I'd get a odor with it, that's a hanging point on the idea. Anybody out there use it? Thanks!
