Problem with my oil pressure
ford-mutt
West Germany
Hi,
when I start the DD 3-53 engine the oil pressure is over 110psi and the oil is coming out of the oilfilter.
After a few minutes the pressure is around 60 psi and no oil is coming out of the oilfilter.
Do you have a idea where the error is?
I think the oil pressure regulator valve or the bybass valve is the problem.
I have a second DD 3-53 engine and there is the same problem.
Thank you,
Franz
