Problems with my Deuce
Brad Nitzke
Poy Sippi, WI
Ok so i bought a deuce from a guy and he dint give me the keys. wtf. i didnt know how to unlock the door so i smashed in the window and when i got in and hit that red buten and it didnt do anything. so how am i going to get the keys for it? i keep calling the guy but no answer. i dont know what to do, :???:
Adrian A
Fresno Ca.
If there is a key switch, you could bypass it. The long hook switch needs to be on. There should be a buzzing noise when it is flipped up to 9 o'clock. That is the accessory on switch and turns on the start circuit and fuel pump. The red button will only work when this is on.
fuzzytoaster
3,685
Fort Worth, Texas
How..what..hmm..
The key sounds like an issue between you and the other party. If you bought it and don't have a key something smells fishy. If you bought it where is it and how did it get there without a key? If your signature is true; "I was 16 when i got a duece " then you should know how to start it unless it's been rewired completely and even then..why did you buy it? :confused:
o1951
155
Bergen County, NJ
How..what..hmm..
If you bought it and don't have a key something smells fishy. If you bought it where is it and how did it get there without a key? If your signature is true;:confused:
Especially when the guy isn't answering the phone.
I would be checking to see if title is legal, rite quick. Could be stolen.
Hope you paid by check and can stop payment.
HanksDeuce
263
Prairieville, LA
Since you are probably still a teenager (based on your signature file), and we all know every teenager has a smartphone, how about taking a few pictures and posting them up for us to look at? We could look at the dash and the battery box and probably tell you what the problem is. Maybe...
3dAngus
102
Perry, Ga.
I am guessing this thread is gust a waste of sewrver space ,since he posted this thread 2 years ago My 1st Deuce .
Maybe it is a case of PWI.
That was NOT the same thread. It was his first deuce back then. This is different, with a picture of his first deuce as his avatar.
It's probably a hoax. Who picks up a deuce from a person at 11:30 at night, breaks a window, looks for a key he doesn't need as the door handle screws are on the inside and he can remove the door handle. It sounds like a poorly conceived hoax but, the point is, the two threads have absolutely nothing in common. The thread as written, is suspect, but plausible.
porkysplace
1,496
mid- michigan
Post # 1 of this thread says nothing about when he bought it or if it is a different deuce . The point of my post is if he had a deuce for 2 years he would know you don't need a key or power , just give it fuel and a slight nudge from another vehicle and it's running.
3dAngus
102
Perry, Ga.
Why should it??? The assumption when you read these things is, he just purchased it. In this case, it would be his second purchase.
You need a key if the door is keyed. He said he had to bust out a window because he didn't have a key.
AT 11:30 at night, and with a motorcycle?. You don't have any of the details. Let's get the facts straight before we go flaming someone with all the speculative hoopla that
is totally unfounded.
Again, it may be a hoax, but there might be hundreds of them on this board. We need facts to respond appropriately, whether if the original post is true or not, and we can always learn something along the way. I wouldn't bet money it's real or not, but I would bet money your post is totally irrelevant and inappropriate given the inaccurate responses you've provided.
porkysplace
1,496
mid- michigan
OP ;[h=2]
Problems with my Deuce[/h]
I don't see anything about a motorcycle in his post or the time of day he went to get it . The only time shown is when he posted. It could have been the day before if the truck even exists.​
Warthog
244
OKC, OK
As a moderator this type of thread waste alot of time and resources.
If he has owned a Duece for two years he should know how they operate.
One thing I DO KNOW is that the f-bomb is not accepted here , even if it is "abbreviated". So for that he is receiving an infraction and this thread is being closed.
Think about your actions before hitting the enter key.
