Pull Start??
gimpyrobb
dumpsterlandingfromorbit!
27,787
779
Cincy Ohio
Yup, my 5ton had a bad starter so I had to pull start it. Just make sure the shutoff valve is not pulled out.
CUCVFAN
Gunner's Mate First Class
47
Jarrettsville, MD
reb87 said:
Can a 5ton or 2 1/2 ton be pull started if the batteries are dead? Just wondering
Ross
The pull-start handle can be found under the passenger seat. Sometimes, the recoil springs stick a little, but just pull the rope gently after it's starts and it'll usually go back in. :p
jwaller
19
Columbia, SC
RE: Re: Pull Start??
make sure if it has a cummins that you open the injector pump manually. if not it wont crank. they have an electric fuel cutoff. it's easy enough to install 2 good batt's so why not?
Alredneck
Banned
1,494
15
TN
Pull started yea, heck if you had enough joes behind ya you could push start the heavy bastard !!! :grd:
